G'day all, 1st post, be kind
For quite some time our broadband has had a terrible problem with randomly disconnecting for no reason whatsoever. So days it'll work fine other days if any of our phones are picked up to make or receive calls it will disconnect and some days you cant even use the internet because it will go down literally after loading 1 page. Naturally this has tried my patience to the limits and beyond. We've also noted that occasionally when on the phone, there is ALOT of background noise on the line, which can at times make it difficult to hear and be heard.
I got in touch with BT who took me through the 'take front plate off and test it yourself' routine, they also tested the line on their end and said it was ok, but sent us a new handset since ours was 'out of date'. we set it up but the problem persists...
I had a hunch earlier and decided to take the 'testing' a step further...i unscrewed the frontplate on our NTE5 linebox and also took off the backplate (i only realised that touching stuff on the other side of the backplate is a no-no afterwards), the inside of our backplate looks like this:
All 6 of the terminals have the 2 coloured wires going to them, and the A/B terminals at the top have a red and white wire going into them. However the E terminal (which i assume stands for Earth) doesn't have anything screwed into it, i also noted that with the collection of wires coming out of the wall there is a green and a black wire that aren't connected to anything...you see where i am going with this?
I know its something we could get in trouble for, but if that is a ground wire that is supposed to be connected to the E terminal and one that might stop all this horrible unwanted noise on the line, would it be a good idea to connect it? We dont want to have to fork out for an engineer to do a job i could do in 5 minutes with some wire strippers and a screwdriver.
Cheers all!
Cheers all!
