BT wire clip gun?
4 Jun 2004
Does anyone know if you can get a tool that clips speaker wire or phone wire to skirting? Apparently BT used to use them. The result is a thin pin in the shape of a U, which is a lot neater than cable clips. I'm trying to source one on the t'internet but am having no luck.
Moderator
Moved as originally posted in WRONG FORUM (general diy)
yes its called a stapler! you want a builders stapler, most will come with an attachment that you can turn over to do flat stapling or cable clipping. should be about 20 from most diy sheds
Thermo
A stapler! Doh! I thought it would be called a gun. Thanks a lot. I'll seek one out.
