Hi all,
Having a bit of a nightmare with Severn Trent.
We applied for planning permission to build a new detached dwelling. ST were consulted during the planning phase and didn't object (they didn't respond at all). Planning permission was subsequently approved.
Side note, when we bought our property the drainage search showed no drainage on our property. Does anyone know who's duty it is to update the map?
We have a foul and storm 100mm gravity sewer running down the back of our house. It serves one property other than ours.
We submitted a build over application because there are also two manholes within the footprint of the new build. The application was submitted in June 2018, we chased in December as we'd received no response. A response was finally received in January 2019 (when we'd started work clearing the site) and it was a rejection because it is ST's policy not to allow build-overs to new dwellings. I can't find any mention of this policy anywhere on ST's website. it actually states under new build: "We'll work with you to provide our consent so that your project may proceed; ensuring that both your property and our pipes are protected."
ST will not allow a diversion or build over, we are having to submit a planning amendment to move the building forward off the drain. They have also stated we could then build an extension over the pipe and they would be ok with that as it's an extension! So we'd end up with the exact same building.
Our architect submitted an identical application for another client recently and that went through with no issue.
I feel like we've just got unlucky with the engineer that's picked up our case. Has anyone appealed or escalated a case successfully with ST? I'm just not sure which route to take at this point.
