Can anyone please advise me? We have recently finished an over-garage extension to create a new bedroom. However, since the builders have left we are getting what I can only describe as flapping noises in high winds from the roof which is so noisy we are unable to sleep. Is there any easy way to fix this.
On looking at roof felt it appears to sucking itself in and out, so creating the noise - seems too loose!
OK - so that sounds not too bad then but the wind rush up there is terrible in high winds and it basically sounds like we are sleeping in a tent in the new room despite having all the insulation above us.
Oh god - presumably via the eaves but we do have a knock-through between the original roof and the new one. The old one is fine as has older tough underfelt but this one seems to sag a bit too much. Hubbie thinking about bracing it back up against trusses. It is extremely dry though and has withstood some terrible weather as we are very exposed. I can put my arm down the underfelt and feel the tiles - 2ft overlap - maybe just gaffer tape the overlaps from the inside????
