M
marsaday
Where do i start with putting a new window in my bathroom. i will be bricking up the current one first and then moving it 70cm to the right (if you get what i mean).
It is a solid, non cavity brick wall 235mm thick. The opening will be 640mm and i intend to use one prop with an eye holding up the brick work above the new lintel.
So after i have propped the window how do i go about it?
Do you insert the lintel first or do you do the cill first and then work your way up taking out the bricks in the way and making good the sides?
