hi, i personally would use 18 mm for the unit carcass, and 15 for the drawer,
and mabe 3-9 mm ply for the drawer base, thats about the sizes we use at work, hope this helps
will you be buying doors or making them from scratch?
if your making from scratch try and match it best to nearby doors, eg thickness, colour and moulding style, you may like to use a router to put a round or ogee on the edges, you could use 18-22 mm mdf if you wanted or
make it out of a wooden frame, two rails, two styles and then an inset panel in the centre
all proberably too complicated just for a door though
