Building over Flue
29 Jan 2007
Ayrshire
I'm building raised decking at the back of my house just now, and the floor is going to be over the flue for my combi-boiler. Is there any reasonwhy I can't do this, providing I leave air flow for ventilation?
NO way that would be ok
consult the insatllation and service instruction manual for your appliance or call the manufacturer for the spec and you will see that you cannot
Sounds a definate no, no but.
If the decking was treated as a balcony, clearances and manufacturers instructions met, this is possible,
The helicopter housebuilder does this all the time!
Why people want to sit on the decking breathing in CO2, I don't know!
Better to extend the flue beyond the decking if poss.
Thanks.
:idea: I was thinking about putting a 90 degree a bend on, and run it out of the end of the decking (about 1.5m), does that sound feasible?
Yes in theory!
But you may run up against another problem.
The standard flue is not designed to be exposed to the weather. Whilst people sometimes fit it underneath a solid water tight balcony even that is questionable.
In your case I think that it would probably be unsuitable but you can ask the manufacturer.
Tony
