Hi;
I am building a small workshop in my garden, project here. The back wall is already in place and is full height so I only need to build three walls which will be about 1m of block above which will sit a wooden frame that will be clad with T&G.
I intend to build two side frames and because of the half block construction the front frame will be a bit tricky and may be in two parts (either side of the the door opening) but have a single top stud on which the roof joists will sit.
For the timber frame I am going to use 100mm x 50mm kiln dried timber.
Looking at lots of plans on the web all the constructions seem to be similar (horizontal and vertical beams - no triangles).
Questions:
1. Where the studs meet what joints do I need? lap Joints?
2. What wood should I use - my suppliers are Wickes and Travis Perkins mainly?
3. How should I join the wood frames to the blocks (what type of screw fittings?)
4. How should the timber pieces be orientated in relation to the frame i.e. with a 100 x 50 piece of timber should the 100 section sit vertically so that the frame only spans half the block wall? Or should it sit flat so that the 100mm width of the block is covered?
More questions soon I think.
Questions:
