Built-in wardrobes with sliding doors
15 Nov 2005
Hi
I want to put a set of wardrobes in my bedroom along one wall, and possibly an overbed cupboard too....but that's a separate question.
I've been looking at the Ikea PAX range which looks great but doesn't quite fit the dimensions I'm after, or it gets pricey when you add up all the bits.
The space is a simple one - square walls and ceilings, so I'd want something which is ~2300mm wide, ~600mm deep, and~2300mm tall. The width would be split in half to give 2 separate sections (one for me, one for the wife). Each would have a hanging rail and some shelves. I'd like to put sliding doors on for space saving reasons.
It seems like an achievable project. I need experienced advice on:
  • Material choice
  • How to ensure cuts are straight (do I need a table saw?)
  • Building and hanging sliding doors. I'd like these to be quite stylish, perhaps with mirrors and contrasting wooden sections a bit like the Ikea ones
  • Fixing the structure to the wall
I'd be interested to hear your opinions, and experiences of similar projects.
30 Jun 2012
Yorkshire
You have one fundamental thing wrong.
You said "half for you half for the Mrs".
Shouldn't it be 2000mm for the mrs, 300mm for you?
Do you mean, in plasterboard up timber?
15 Nov 2005
You're probably right. My OCD requires that it's equal on both sides, but the reality is that she'll use 85% of the total space :LOL:
I'm not sure what you're asking here (typo?). If you're asking whether the walls are plasterboard or timber, the answer is they are both plasterboard. Though the left side is an outer wall so is solid brick behind the plasterboard. The back wall is a partition wall so just plasterboard on timber. The right side will not be fixed against a wall other than at the back edge.
14 Mar 2006
Kent
Hi
  • Material choice
Bit of a contradiction here sliding doors of any quality will be more expensive than an ikea wardrobe. Why not build in the unit and fit ikea doors, have done this in a few bedrooms.
15 Nov 2005
That's a great idea, and I'm keen to give it a go.
I'm looking for tips on building the frames now.
14 Mar 2006
Kent
Simple mdf frame is quick and easy, cut too size at supplier.
