Custom sliding door wardrobe
6 Feb 2014
Staffordshire
I'd like to make a custom sliding door wardrobe on the next bedroom I do. I'd like to make it the width of the room (I'll be plastering the entire room too)
Is it just a matter of buying runners and doors to fit then making up the internal shelves? or if there more to it?
Any tips, advice.. direction is much appreciated
POT
7 Feb 2008
Northumberland
That plus a good sturdy frame to fix the runners to, and you're well on the way......consider diyhomefit.co.uk for what you need!
John :)
14 Mar 2006
Essex coast
You need to consider the door width which need to suit the width of the room, generally come in 60cm or approx 90cm width but can vary, with a slight overlap.
Width of a door may make access to rear difficult so also has to be taken into consideration.
Generally no frame required as door weight is usually taken by floor track.
My bedroom below.
6 Feb 2014
Staffordshire
My bedroom below.
wow, WOW. Very nice, this is EXACTLY how I want mine, don't suppose you did a step by step 'how to' when building it ? :oops:
14 Mar 2006
Essex coast
Sorry. no step by step. Had draws from plans chest so incorporated them in design, internals are just painted 18mm mdf. Required a panel to left wall to compensate for room being slightly too wide for 3doors but too small for 4.
Top is just a 3x4 timber full width to take upper track and strip of mdf to hide along with the upper track as Mrs did not like the brushed metal on show.
Vertical panels and shelf is 18mm mdf secured to rear wall ,ceiling and floor with metal angle brackets.
I don't aim for a tight fit with internal panels as it helps with ventilation as outside wall can cause damp if not ventilated.
Lots of wire or plastic draws available from kitchen suppliers/ikea if you want draws.
