Bulging artex from leak above
8 Jun 2013
Gloucestershire
I've cured the leak and left it a good month. How best to 'stick' back the bulging artex please?
I'm thinking, inject some form of adhesive, grip-fill etc and then screw batten across to hold in place.
I'd certainly rather not take it all off and re-artex, or skim etc
What I have done (successfully) on plaster where the skim was a bit hollow sounding, was
Drill a small hole ( can you access the ceiling from above easily? If not don't bother.
Use a syringe to inject a slightly watered down PVA into the area. The kind of spring that would worry you if the Dr produced it.
Use a bit of 2x1 that almost touches the ceiling. onto of it, fit a dinner plate sized bit of ply, single screw. Cover with carrier bag.
Slide under the sagging bit and kick the 2x1 to push it against the ceiling.
12-24 hrs and it will be fine. Be careful in case the bag sticks.
Ah, yes! That's the sort of thing. I'll probably use SBR rather than PVA though in case the leak happens again (it's from a dislodged shower waste above) but definitely the right 'sloppiness' and securing idea.
Thanks for that.
