Bungalow Painting
19 Nov 2006
My bungalow is in need of exterior painting. I can manage the side walls and the lower half of the apex walls, but I am no good on ladders, so the top halfs to the apex are a problem. Is there any succesful method of painting from ground level with an extension device, has anyone used a method like this? or do I have to have scaffolding erected and employ someone to do these two small sections. I would like to avoid the cost if possible if there was another way?
Any help would be appreciated
Get yoursdelf a decent extention pole..check the end to make sure your roller arm will fir ir and use that..the onlt problem is you wont be able to cut in..
