I have a Ideal Logic Plus combi boiler.
When I turn on the central heating the burner is constantly on (at least the burner light indicator suggests it's always on). Is this normal? Seems to use a lot of gas when I use the central heating. I would have thought that the burner indicator would go on and off when needed rather than on all the time.
Also, I have turned the temp of the rads to 78 degrees. The rads are very hot to touch by hand but for some reason does not heat the room up very well. Is 78-80 degrees, for the rads, normal temps or would you expect higher or lower to heat a house properly? I'm not sure if it's the boiler at fault or bad insulation or maybe the rads not large enough?
Any thoughts/advice appreciated!
