- Joined
- 29 Dec 2025
- Messages
- 4,302
- Reaction score
- 225
- Country
What case law?Is this statute, guidance, case law?
The cases that you haven'r presented?
Like your refusal to present the relevant sections of the legislation or the cases that you keep referring to. titterspeaks volumes.
And suffer the consequences for his judgement of 'the right thing'Sometimes you've just got to do the right thing
Who knows.What case law
I'll beEvery bond you break, every step you take
Posts a link about household intrudersYou don't.
Wrong law dummy.
Welcome to 'bikings legalese roundabout - a tale in the round which goes around and around til nobody can remember what the point of it is.I have asked multiple times for you to present the relevant section of the law that you refer to, yet still you resist. There can be only one explanation.
How about presenting some case law, to which you have now switched, that supports your interpretation of the relevant law.
I’m not the one denying what the law says. It’s only two sentences. It can’t be that hard even for the usual trolls… like you Himmy, Nosenout and troll mod.Welcome to 'bikings legalese roundabout - a tale in the round which goes around and around til nobody can remember what the point of it is.
Dante's fifth circle of Hell.
Reasonable force, dummy.Posts a link about
Nonsense. It's UK criminal law dummy. The case tested the 'reasonable force' threshold, dummy.Wrong law dummy.
titterNonsense. It's UK criminal law dummy. The case tested the 'reasonable force' threshold, dummy.
unless the use of a weapon is not disproportionate. Belief that the suspect is armed, weapon was something readily available, rather than a specific prohibited weapon etc.Always.
This is still true though and why chicken bikers is so embarrassed...
The Criminal Law Act 1967 does not give you a blanket right to chase a fleeing suspect with a weapon. While Section 3 of the Act allows for the use of "reasonable force" to prevent crime or make a lawful arrest, using a weapon against a fleeing person is extremely likely to be deemed disproportionate, excessive, and illegal.
isn't true because:And this....
The Legal Position (Criminal Law Act 1967)
- Reasonable Force Only: Section 3(1) states: "A person may use such force as is reasonable in the circumstances in the prevention of crime, or in effecting or assisting in the lawful arrest of offenders or suspected offenders...".
- Proportionality is Key: The force used must match the threat. If a suspect is running away, they are generally not an immediate threat to you or others. Chasing them with a weapon implies a desire to harm or punish (revenge), rather than to stop a crime.
- Grossly Disproportionate Force: If you chase a suspect and use a weapon—especially if you cause serious injury—it will almost certainly be considered "grossly disproportionate," and you may face criminal charges, including wounding or assault, regardless of the fact that they stole from you.
which is correct.It all comes down to the individual facts of each case. In the heat of the moment, a defendant isn't expected to weight the niceties of the situation precisely.
which is a case almost entirely about the common law defence of reasonable force to defend yourself in a home intrusion. It doesn't address the statutory defence that a person has under Sec 3,1 Criminal Law Act 1967 giving power to use reasonable force :Nonsense. It's UK criminal law dummy. The case tested the 'reasonable force' threshold.
(1)A person may use such force as is reasonable in the circumstances in the prevention of crime, or in effecting or assisting in the lawful arrest of offenders or suspected offenders or of persons unlawfully at large.
