Bus driver sacked OMG
Irrelevant.
Nope.
What if I chase them as they run off?
This situation is different as you are no longer acting in self-defence and so the same degree of force may not be reasonable. However, you are still allowed to use reasonable force to recover your property and make a citizen's arrest. You should consider your own safety and, for example, whether the police have been called. A rugby tackle or a single blow would probably be reasonable. Acting out of malice and revenge with the intent of inflicting punishment through injury or death would not.
Chasing a fleeing suspect with a weapon and subsequently using it is highly likely to be considered malice, revenge, or retaliation rather than self-defence in legal terms, particularly if the initial threat has passed.
(Source - CPS)
That rules you and HWM out.
We got there finally! a source. Shame it’s the wrong law.. dummy
Irrelevant.
Nope.
(Source - CPS)
titter
Yes, as I have just posted with an excerpt from the Crown Prosecution Service guidance paper on it. Chicken biker asked for source, and now he can smother it on his humble pie.
18 pages - this one has potential...
then why don't you just clarify the point of contention in plain English.
way too much fun watching you loonies try to work it out. Running around in circles like headless chickens. This is great.
Where I got what from? The CPS report or the chart describing the applications of reasonable force?
The rules and laws surrounding and referring to reasonable force are not relevant to a person chasing a subject with a weapon? Explain?
He is running away with someones property for one
If you promise to listen carefully. I will explain the difference between the well established common law defence of reasonable force for self defence and the statutory right of someone using reasonable force to apprehend a criminal.
And then if some twonk decides to jump in the drivers seat and have a joy ride, you then have several passengers and a whole lot of expensive bus shaped property to deal with. That and the fact that the insurers have now voided your £120k claim because the bus was unatended.
