Bush fridge freezer
1 Jul 2014
Hartlepool
My freezer has stopped working on my Bush fridge freezer, is it possible to repair this or is it not worth it. Any help would be very much appreciated, cheers.
is it stored in a cold room [around 6 degrees or less]??
Yer, its in the garage. I'm thinking as it only has a stat in the fridge compartment this has shut down with the recent cold weather, would you agree?
yes the fridge is happy so it wont run
you need to warm the room or swap with a fridge or freezer in a warm room if you have the choice
if you turn down the fridge stat, presumably the compressor will start up
the biggest trouble is they are often a compromise if they only measure the fridge temperature
during the hot days off the summer the freezer will be far colder than required
and during the cold winter the freezer will be much warmer than it should be
this is why i never store anything with a short shelve life or fish along with chicken in the f/freezer
