Buying sanitary ware.
5 Oct 2007
Sussex
I’ve been plumbing now since 1968 and I cannot believe how much substandard sanitary and brassware there is on the market, especially online. I am much relieved at the demise of the bath store. I am so fed up with explaining to customers that anything they buy is their responsibility and not that of the installer.
if you upgrading your bathroom, do not be seduced into thinking that it is cheaper if you supply. You will most likely go to one of the sheds or look online. You may well find that a local independent will be as cheap or very little more. Your plumber may well make a profit if they supply but then it is their problem when things go bad.
