buzzing dimmer
1 Aug 2006
Cheshire
i fitted a new light to the dining room which has about 10 litttle bulbs with two prongs for fitting them
the light works fine, but then maud decides a dimmer would be a good idea. I bought a dimmer and fitted it but the actual dimmer switch buzzes like a nest of wasps!!!!!!!!
why is this ????????
i removed it straight away and put the original switch back on, but maud still wants the dimmer
What is the rating of the light fixture? and what is the max load for the dimmer?
Is this an elv light fixture, and if it is, is the elv source suitable for dimming and is the dimmer suitable for use on reactive loads?
take some lamps out then it will be dimmer.
why buy a light with so many lamps then dinm it?
but as said its comaptability between dimmer and light, some dimmers do indeed buzz
hi thanks for the replies
bought the light cos maud wanted it, then the dimmer cos maud wanted it (just easier to say yes)
what ratings should i be looking for the dimmer in comparison to the light
elv ???? no idea
he means is it 12 volt (lamps)
you should check the rating of the dimmer and it should be more than the total of the lamps
i.e 10 x 20 watt lamps you cant use a 150 watt dimmer
also if the lamps are 12v does the transformer say "suitable for dimming"
it may be mains, but what voltage are the lamps?
not allbut most "deorative lights" are 12v
NS215, I have a fitting with the same lamps as yours (i assume), 10 x 10 watt. I find it quite dim already. Anyhow it has a transformer in the base to change to 12 volts.
Many transformers will not work with dimmers, and visa-versa.
I have to say you aint being particularly forthcoming with info that we need. We still dont know the voltage of the lamps, the type of transformer if one exists (take a piccy if you want), the total wattage of the fitting. We need all of this to make any advice.
I assume this light is only switched from one location. Please confirm.
or like
either way we need more info
just checked the bulbs and they are 12v 10w and 10 of them on the fitting
Look inside the base at the transformer and take a photo to show us. Also note if the words dimmable or non-dimmable appear on it anywhere.
will do steve but it will be tomorrow now after work
thanks for all the replies
