Buzzing Myson valve
5 Jan 2007
Hope someone can help me. I need a decent nights sleep!
Both Myson power extra motorised valves in the hot press buzz LOUDLY usually when the heating is on but also in the middle of the night when its off. I presume that they are sticking and not able to fully open.
I was going to replace the heads and cross my fingers that this solves the problem. I have removed one of them from the valve and the valve itself moves easily. The manual lever though has no effect when moved.
Is replacing them the right thing to do? oh yes, the way to get them to stop buzzing is to turn down either the upstairs or downstairs thermostat (depending on which one is making the noise)
Is it an easy enough job? Thanks
never found these to be very reliable.....if you do change them it probably wont be the last time.
i had one head that lasted a mere 3 months....ended up just changing the whole valve for something better
