Hi see photo
System fitted 10 years back.
A year ago I put the red magnet you see on the pipework to the left of the bypass valve and it sticks, had plumber removed the pipework, and full of metal. I noticed pipework had a slight fall to bottom right so things settling there.
Today I had a look a year later and it's back again full of metal hence magnet sticking. This a mistake surely by installer? If so to save me paying for a plumber, I do below?
Drain system (done a few times before over the years)
The two compression fittings either side of the bypass (that have three points a spanner could go to), might be obvious but I loosen the ones near the bypass, while holding the middle bit?
I guess could get plumber to fix the angle so things don't keep settling here also.
