M
mysteryman
Do the job properly, simply and effectively with the best equipment, and you will not need 2 port valves. The best boilers have a built-in diverter valve. Why make the job more complicated than it needs to be?
Turning now to your temperature settings for Radiator flows I need a bit of reassurance. My understanding of radiator output power is based on fairly standard figures of 75C flow and 65C return thus giving a notional mean of 60C.
I would expect the mean of 75 C and 65 C might rather be 70 C ?
But I like to have a differential of closer to 20 C with a condensing boiler rather than the 10 C suggested above.
For your information, though you know a great deal more than I about heating installations, the Alpha2 pump works perfectly on overrun. What are you talking about?
They have not given me a warranty - you are right, but he did not think it had to be condemned thank goodness. The Plumber will be placing a new HE in front of me with all relevant parts before I pay his bill!! I decided not to accept his offer of a twelve year free guarantee in lieu as I doubt his firm will exist that long!
smokebox
I realise the smart pump runs on the over run. But it is not providing an over run flow as required by the boiler because it does not increase the pressure in order to open the auto by pass.
Unfortunately I did not explain that in a simple form.
Smart pumps are fine for the application they are designed for. I fit them when appropriate.
Recent permanent magnet pump motors however are much more efficient and are easily modulated.
You have now brought in a new revelation of not paying your nupty installer until he brings you a new ( expensive ) spare HE. As the problem seems from the evidence to have been as a result of your insistance on having an incompatible smart pump then I dont see that your installer is to blame.
Based on just what you have told us he does not seem to be terribly clever at system design. But that should not make him to blame for system failures as a result of following your specific requirements.
But I could criticise him for not refusing to fit unsuitable components. I always take the view that no installer should fit anything that he does not fully understand. But if everyone did that then very little would ever get installed.
The customer always thinks that he is right !
Tony
Why do you insist on fitting an auto by-pass? It is not mandatory.
The fact that this has killed a Vaillant HX is even more reason for me never to fit another one.
You have a strange viewpoint of the industry, but not totally uninformed (often more dangerous than no knowledge at all).
Your plumber is probably under-qualified, under-experienced and worried about not being paid. He has possibly bought an entire boiler to hold as spares in order to supply your new HX.
Even so, if such a minor error of installation could actually cause this type of damage to a HX then I sure as hell wouldn't want one in my house.
Think about it. This is a pretty minor error on the part of the installer and should in no way have caused HX failure after a few months (I am assuming) or operation.
Shoddy manufacturer IMO.
But again. Why do yo insist on overcomplicating the installation for such a minimal gain in efficiency? The cost of the computer and internet time sp far will probably out weigh any benefits you will gain.
