I have an old (20yr) gloworm hideaway floor standing boiler coupled to a fully pumped s-plan sytem. The pump is on the return at the moment and i want to put it on the feed as it's a bit noisy.
It's a long story about a back boiler being removed and the feed and vent going to the old back boiler location rather than the main boiler. I wan't to re-instate an old feed and vent on the main boiler tappings, but i can't unless the pump is pumping out of the boiler rather than in.
The hot water primary is 15mm, the pump is on a 22mm. There is no bypass insalled at the moment. Due to this restriction, should it have one?
