C/H Timer wiring help please
14 Aug 2007
Nottinghamshire
Posted: Wed Jan 16, 2013 4:06 pm
Hi All, Can you help please.
My house is empty and For Sale but I kept heating on cos of the cold weather. It stopped working a few days ago.
The Switchmaster SM300 clock has stopped and buzzes faintly. if I manually turn it, the 'pegs' turn Heating on and off correctly so I presume the clock motor has packed up (exactly like the last one 7 years ago). My local shop advised me there is no direct replacement and suggested a Siemens RWB27 which I bought.
The backplate on the RWB27 is set out exactly like the SM300 i.e. N.L.1.2.3.4. but the wiring diagrams on back of both timers is different and frankly I do not understand the paperwork that came with the RWB27.
(especially since the SM300 isn't listed there).
The boiler is a Ravenheat RSF 82 fanned combi and there is a Room stat.
There are 3 cables into the SM300 backplate
Cable 1 is 4 core, it has a Black to No.2, a Blue to N, a Brown to 1, and an earth.
Cable 2 has earth chopped off and a Blue (red tape stuck to it but not carefully wound around) to 2 and a Brown to 4
Cable 3 is from a fused spur, N L and Earth to their respective places.
Can supply pictures if required.
Can anybody advise me the wiring to the RWB27 pls? would like to get heat back on asap. Many Thanx Carl.
Read more: //www.diynot.com/forums/electrics/c-h-timer-wiring-help-please.351612/#ixzz2IAspadiB
Yes a pic would help.
Cable 2 we need to know. so leaving that safe for now.
The old 1 goes in 4.
The old 4 goes in 2.
The old 2 is 1
Cable 3 goes the L&N
forgot to answer your last question
Cable 2 blue (with red tape on) goes to No 2 which is a spare (no pin on back of sm300)
and the Brown goes to No 4
What is the make/model of the room stat.
Can you id the colours with numbers in the stat please.
I think cable 1 goes to the room stat.
Subject to your confirmation.
Cable 1
Brown to 4
Black(red tape) to 1
Cable 2
Brown to 2
Blue to 1
Cable 3 L&N
The terminals on the switch master are
L & N
4 Is common,
1 is on
Terminal 2 is being used as a connector
Your RWB27 terminals are
L & N
2 is common
4 is on
So just follow DIA's earlier post
If cable 1 is the room stat cable then you need to disconnect the neutral to it
As your boiler has volt free switching so doesn't req it
But cable 1 could just as likely be connected to the boiler
Matt
Hi Guys
I see you’ve been busy whilst I was away but since I have the pics now, here they are for you to see.
The cable in the Honeywell Room stat is 4 cores which presumably means its Cable 1 as there is only one 4 core cable at the SM300 timer switch and it has the same colours. Inside the room stat the Blue is on No 2, the Black (with Red tape around) is on 3 and Brown on 1 (which is actually 5th screw from left) then there’s the Earth.
The connectors in the stat, from left to right are: Earth, 2, 3, 4, 1 . . . 5 and 6 are empty.
wiring diag inside stat lid
I really appreciate your help guys, thank you.
Cable 1
Brown to 4
Cable 2
Brown to 2
Blue to 1
Cable 3 L&N
Just follow the above.
The blue in cable 1 goes to N as before
Or if it's easier.
The old 2 goes in 1
L&Ns are the same
Doitall . . . Thank you very very much
It's up and running . . . the jobs a good un
Thank you
Also thanks to Matt for his input.
Best Regards
Carl
Thanks for the feedback Carl, always good to know when it goes well :cool:
