Any suggestions for a useful large size CU?Split load.
How many ways req. in a typical 4br house?
What make?
Who will supply fully assembled CU's?
I've researched this topic but haven't come across an answer.
The items on the list below may not all apply to you, but they are worth looking at to get you thinking:
Upstairs sockets
Downstairs sockets
Kitchen sockets
Radial for appliances
Cooker circuit
Non-RCD circuit for F/F
Non-RCD circuit for CH boiler
Dedicated circuit for hifi
Dedicated circuit for IT equipment
Upstairs lights
Downstairs lights
Immersion heater
Shower
Alarm
Supply for outside lights
Supply for garden electrics
Supply for shed/garage
Plus any peculiarities brought about by your house layout & construction - e.g. in mine because of solid floors and where the rings run, I have a radial just for a socket in the hall, the doorbell and the porch lights.
Plus a few spares on RCD & non-RCD sides for expansion beyond that for future unforeseen needs.
Assuming you choose not to follow Qedelecs advice there are additional considerations if your house uses TT earthing i.e. You will need to swap the main incomer with a 100mA Time Delayed RCD which isn't difficult to do but will add around £60 to the cost.
PartP aside, from a safety perspective alone Qedelecs advice is sound and unless you really know what you are doing I'd get someone in to do this as you'll be pulling service fuses and there are many exposed dangerous bits within CU's etc.
