T
teddyb
Moved house. Garage has power and light via a small c/u with 2 fuses. The casing of the c/u is cracked. I have bought a similar sized c/u especially for the garage which has an RCD instead of a simple switch.
There is an integral thick blue cable in the unit - between the neutral block and the RCD itself.
Can you please advise on the where the cables go?
My incoming mains to the RCD?
Circuit lives to the MCBs?
Circuit neutrals to neutral block?
Mains neutral to neutral block??
All earths to earth block.
Do I need to earth the unit itself? If so how/where?
