Cabinet doors for a 600mm tall cupboard
21 Mar 2021
I've decided to put up an extar 60cm cupboard in my kitchen but thinking the door size could be a problem because of how far out a 60cm door would swing. I'm wondering about using two 30cm doors instead, but this means there'll be a gap between the doors, so I'm worried that will look messy.
I can't see any designs were this has been done.
Has anyone done this and if so how did you resolve the gap between the doors?
or should I just stick with the standard 60cm door?
you can get two 300mm doors and hinge them in the middle.
or if using modern cab hinges, they have a lot of fine adjustment so you can get a nice gap.
All doors have gaps or they won’t open .
Thanks, think you hinge in the middle will work well
