I've just moved into a property which needed a fair amount of cosmetic work. In the process of doing this I have found that the downlighters in the hall have been wired as follows:
1.5mm2 cable run through the ceiling from the light point to the wall then back down through the ceiling. It then goes accross the joists using the void behind the coving as a conduit.
Is this acceptable Or should it be run in plastic conduit? I only had to remove a small section of coving to repair the area but if needs be I will rip the lot down and get the job done properly
Matt
Matt
