I have just taken delivery of two TP DB's, one for the off peak, and one for the peak supplies.
One is 8 TP ways, one is 4 TP ways. One is HARMONISED, one is NOT!!!
As this is a new install, I need all harmonised, but the wholesaler doesn't have the goods! What to do? does it really matter that the stickers are a different colour?? (Merlin Gerin would also have plastic coloured tags on the outgoing ways).
I dont know......
Give me RYB any day.....BBG doesn't have the ring to it!
The las MK boards I bought had a patch of stickers to Harmonise the older cables and board labels. Last Cheap& Cheery Denmans ones were fully Harmonised, suppose it depends on how fast they clear the old stock. Use tape and break out the box of crayons?
we should go back to the old colours. if europe want to use the same colours, they can change to RYB. at least you can easily see the diffence between the colours and if you see a bright coloured cable it obviously indicates danger
