Cable finder
6 Mar 2007
Essex
Hey guys,
I'm on the market for a good cable detector, to check cables behind walls etc.
The one I have is quite basic and and has a limited range. It certainly doesn't give me peace of mind.
Any recommendations would be appreciated.
Thanks in advance.
Bosch DMF 10 Zoom
Have a search around as you may find it cheaper.
Thanks Gary Mo.
I will have a search around for prices.
Is it one you use or just seen ?
I have one and find it better than any other model I've used though admittedly other models were cheaper.
I have one, think its black and decker. Its ok for interior stud partitions and plastered walls but fails on my ceiling and outside walls. Due to the vapor check plaster board i suspect because it has a foil backing. Is this true for all the detectors on the market.
Thanks so far,
I have found the Bosch DMF 10 Zoom for £47.
Not to bad i guess,
what about an infrared version anybody used one of those ?
