Can someone advise ... a domestic flat conversion (less than 70 kva), the CU may be sited 7mt away from a meter, the cable would need to be run up a wall through a floor and up to the CU
1) Can the cable be 16mm singles in a wooden enclosure (12mm ply) running up the wall in a bathroom, or should it be inside metal trunking, or should it be armoured.
2) The CU may be sited in an alcove just off the loft stairs - accessed by a small ladder (similar to those found on a bunk bed). This alcove is directly adjacent and beneath an incoming feed from a 3kw solar panel supply, where an inverter will also be installed.
Any comments on the viability of this appreciated.
