Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I currently have my ring main dropping down from the first floor void through the cavity space in the walls then exiting at the bottom and into the power socket. house is 1950's - is this ok/permitted?
If you saying the cavity is between the brick courses then it's not allowed.
If your saying the cavity is between the internal brick skin and the dry lining / plasterboard that is OK providing it's in the sfae zone and suitably supported with fixings.
Because if you have cavity wall insulation your cables may overheat. Also cavity walls are a nice place for vermin to hide and they like the taste of PVC. Oh and certain types of cavity wall insulation can eat away at PVC insulation too.
I'm not a plumber but I can't see why insulating hot pipes is going to be a bad thing so your probably ok there.
You are not obligated to fix anything that isn't immediately dangerous. The current regulations do not carry over to old installations. Do you have cavity wall insulation already? Any shower/cooker cables in the voids?
