cable in underlay
30 Aug 2012
London
thoughts on running cable in the underlay under floorboards, i.e. by laying the underlay around the cable to allow space for the cable?
I mean the soundproofing underlay, it is slightly thicker than the electrical cable and is quite hard. The floorboards are laid on top
OK - so you presumably mean that the cable would be more-or-less immediately underneath the floorboards? If so, no, I don't think that would be acceptable, for fairly obvious reasons - someone with a drill, saw, hammer and nails or whatever wouldn't have a clue as to where there might be cables which needed to be avoided.
Kind Regards, John
so should be in a conduit, like that thin trunking you can get at B & Q?
what about flex in the boards? I assume these engineered boards dont flex enough to maybe compress the cable?
its a concrete floor. there is a small channel cut and then the floor underlay. the top of the underlay is above the cable.
thoughts?
thanks
If the cable were within 50mm of the top surface of the floorboards, it would have to be in heavy metal conduit.
I think you're going to have to find some alternative route for your cables. Is this underlay lying on a solid floor, or what?
Kind Regards, John
yes, lying on concrete floor
In that case, as I said, you're going to have to find a different route for your cables (maybe above the ceiling, then dropping down walls) - unless you are prepared to dig channels in the concrete for metal conduit.
Kind Regards, John
Hi John,
thanks for replies. thing is has already been done this way about 2 years ago (it was like that when I replaced the floorboards) but now not so sure
was more wondering if there is flex in the boards from walking on it what that might do to the cable
thanks,
