Cable sizing for outdoor spotlight
20 Feb 2020
I'd really appreciate some advice on the right type of cable to wire in 6x 35w GU10 spotlights that will be mounted onto a wooden fence. I already have a dedicated garden lighting circuit and will run the connection via a 20A DP switch. Ideally I'd like the thinnest cable possible as I need to feed the cable through some fence battens. Nothing will be at ground level.
Thanks in advance.
These will have LED bulbs but I'm not a huge fan of LED Strips
6 x 35 watt at 230 volts = 0.913 amp or 913 mA, so a 1 amp fuse is enough, even when considering volt drop 1 mm² would be ample. Not seen any outdoor rated cable under 1 mm² personally would select a round cable, stuffing glands work better with round cable, and black, as black resists UV light better.
The problem here in Wales is Part P regulations require it to be notified, and that costs £100 plus vat, so I would likely look at extra low voltage, so I do not need to notify, or try to claim it was done before 2004.
Not looked at MR16 compatible lights as to their IP rating, in the old days of tungsten I have fitted MR16 in a well, underwater. But getting a fitting to take GU10 and to seal against the elements may not be easy.
Based on this, a .75mm2 cable should also do the job right seeing as it's rated for 6amps which is considerably oversized already?
you could use 0.5mm but i would stick with 0.75 as the outer insulation would be thicker and give more protection
