- Joined
- 14 Feb 2012
- Messages
- 70
- Reaction score
- 5
- Country
Hello all,
I know this is going to earn me some flames but better to ask than be embarrassed at a later date!
The Plan: I want to run a cable up the garden to power some (4-off) 240v LED outside lights to light up the garden path (25 meters long). At the far end I intend to install an outdoor IP-rated 13A socket to plug in a cleaner to vacuum the car or mow the lawn. The whole lot would be powered from an external RCD fed outside socket (as available at DIY stores).
As I'm a tenant I can't bury a cable so intend to make it a temporary 'installation' which can easily be removed when we move out. I was thinking to run a bright coloured cable and clip it to the fence so it's out the way, but close to the ground.
I was thinking to install 'taps' off the main cable using 'Scotch Lock Wire Connectors' protected in IP rated glanded connection boxes. The reason for this is to prevent the possibility of a loose connection if using screw connectors and interrupting the cable at each box. Each box would be mounted below it's light on a wooden 'plank/stake' pushed into the ground.
I know this isn't going to be popular with the professionals out there but I just wanted to know whether it would be OK to use Scotch Lock Wire Connectors in 240v applications. Obviously the load from the LED lamp on each connector would be minimal.
Many thanks for any useful advice...
Stephen
Stephen
