Cable Spacing in Walls
16 Sep 2007
London
Hi
I'm planning to extend a ring main by breaking into the ring using Wago connectors and boxes.
The extension is quite short and I'm only adding one socket, however the cables will need to be chased into plasterboard.
Is there a minimum parallel distance you would recommend between the cables in the wall? Is a couple of inches enough? Presumably if they are too close one cable might warm up the other.
Is this mentioned in any of the current regs?
No, there should be no problems. Quite often the outgoing and return legs of a ring are next to each other in trunking/conduit anyway.
If you are only fitting one socket, why not consider a single radial link? Then you won't need to worry about the cables being next to each other.
Other manufacturers are available.
Do you mean hanging behind it?
No.
This is not relevant in the case of the two ring circuit cables.
If there are no derating factors for the installation method, then the two cables of the ring are capable of carrying 54A so are not going to overheat when sharing 32A.
This is very well demonstrated by Conny's suggestion:
"why not consider a single radial link? Then you won't need to worry about the cables being next to each other."
So, if one (smaller) cable is alright then surely two touching must also be.
Must be somewhere; can't find it at the moment.
