My garage currently has 4 double sockets on it's own ring main circuit from the CU, all neatly tucked away in one approx 8 foot length of what I think is called dado trunking (big trunking one often sees surrounding office or hospital walls, which one can screw sockets/switches etc straight on to the front face). The sockets are for general light use of small power tools, the freezer, a radio etc. I'd like to add a bench light switch to the trunking. I intend to fit a FCU to the ring and obviously an appropriate sized cable supplying the light.
What's the correct way to connect a FCU to the ring main if there are no cable length constraints? Should it be installed as if its an additional socket, ie with both supply cables connected to its supply side, or should it be fitted as a spur from the next socket, ie that socket would have three cables on the supply side and the FCU only one supply cable?
TIA
TIA
