hi guys, im still not having much luck on a ariston euro combi a23mffi.
it is my own boiler so im not getting any pay on this as others in the forum have refused to help thinking i am on a paid job.
ok whats happening hot water runs cold after a minute, on inspection boiler has flamed out and relights itself a mintue or two later so the dwh diaphram was changed. the needle is making the switch and the switch works fine but problem continued.
ariston say this is an air pressure switch problem, which it has been changed and venturi cleaned out whilst at the same time the elctrodes was cleaned. ariston say if it was a circulation problem then the fan and pump would not run during the time it is flamed out.
during the cleaning of the detection electrode it was noted that either the spark generator or gas valve in which it is attached made clunking after which the boiler lit first time and stayed in flame moving to high flame and low flame instead of high flame to no flame, thought to be fixed but not.
today we are back to hot water running cold again.
had an rgi who has not been able to identify the problem as boiler passed on what was being tested.
over heat stat measured 3Holmes
air pressure switch blown into tube and replaced regardless tubes clear as to with venturi
fan operational
pump operational
dwh diaphram operational
3way valve operational
main temp probe on 3way operational(supplys only temperator gauge lights)
as i say during cleaning the detection electode my finger made contact with the burner in which interfered with either the spark generator or gas valve which a clunking noise could be heard not sure whether that is normal or not.
ariston say not circulation
tested what can be tested
replaced parts irrespective as they are likely to deteriate.
im lost with it all now so is an rgi who has helped where he could.
anyone got any ideas....no abuse please and sorry for havign to repost on the same matter as last
fan operational
pump operational
