I put a screw right through the centre of a speedfit barrier pipe Friday night supplying cold mains water to our washing machine. The pipe was clipped to the vertical timber (nicely found by my stud detector) in an extension we had built last year.
Fortunately for me, I managed to obtain a speedfit connector and some inserts from a friend.
Because I had to cut a hole in the plasterboard to make the repair I couldn't get the proper pipe cutting tool through the hole, so I cut it carefully with a hacksaw blade to make sure it was a square cut and then cleaned it with a file. I Fitted the inserts, made the connection and water was restored, no leaks, so no problem, or so I thought.
Checking on the Speedfit website today, it states that you shouldn't cut speedfit pipe with a hacksaw, and it also suggests the use of an "STS" superseal pipe insert which has rubber "O" rings on it. The ones I got were standard inserts without "O" rings.
On sunday I replaced the cut plasterboard and made good the wall. In light of the above, should I open it up again and re-make the connection?
