quite likely you have general accumulations of sludge in all the pipes and rads. You might check all the rad valves are wide open as a temporary aid while you get on with cleaning it.
if you hold a strong magnet to the copper pipes it will be attracted to areas holding black sediment. If the are very bad you can cut out the blocked sections and replace with new pipe.
if it is pumping over, start by reducing the speed of the pump; then tie up the ball valve, then bale and sponge out all the mud from your F&E tank, and drain a bucket of water out, then add a litre of Sentinel X400 which is a mild sludge-loosener, refill it and run it for 4 weeks before draining and rinsing which will remove the loosened sludge. You will know it is working if the water turns inky black. The chemical will cost you £15. This is a very cheap and easy way of removing some of the deposits, and may save you the cost of a Powerflush later.
If you can do basic DIY plumbing and can afford £100, fit a Magnaclean as well, I guarantee you will be amazed and delighted at how much black sludge it traps. It continues working for many years and you empty out the sludge it has trapped
remember you must add an inhibitor such as X100 when you refill.
If you post a pic of the pipes showing the vent pipe, the F&E pipe and the pump, we may see a pipe layout error that you could alter.
