Can a CH pump wear out?
Oh Softus, you presume that I am knowledgable about central heating systems and choose not to answer your questions, surely by now you must have deduced that I am to plumbing what a lobster is to ice skating. How am I supposed to know what heating plan a central heating system is.............surely that is your preserve
So, SambotC you think I need to replace that return T, you've been dead on the money so far, whereas Softus seems just to want to play with words and not make a decision, so replace the T it is, whatsay you Softus?
Please rest assured that I've no such presumption :D
Maybe so, but you claim to have replaced a radiator, a zone valve, and a circulating pump. Sometimes people are less then honest when they sniff free advice.
Simply answer the questions and it will become obvious.
I suggest that you just go right ahead and change your pump.
If you want the free advice, then have a go at answering the simple questions.
Or you could engage a heating engineer and stand him in the kitchen blindfold while you tell him everything you've told us, and see what kind of diagnosis you get. You'll have to provide a bucket into which he can piss himself laughing though.
Softus, you have misquoted me, when you told me to change the pump, you were taking the **ss because my OP you hadn't chosen to answer but instead ask loads of questions, not getting the answers you wanted resulted in that 'personality' coming to the fore again.
So, Softus, if you know that I don't know about heating systems why are you askin me what heating plan I've got?
At no point have I misquoted you.
No. I wasn't.
At no point have I asked you what heating plan you've got. When I mentioned heating plans I was addressing ChrisR, and I didn't ask him, or anyone else, either.
OOps, Softus, no cylinder stat, yes there's a room stat, one motorised valve on 15mm CH flow
if pumps dont wear out why do the manufacturers keep making them :?:
Sometimes they block up, like this one.
Sometimes a pump valve drips water into the electrics.
Sometimes the capacitor breaks down and most people don't know to diagnose and replace them.
and sometimes they just throw the towel in :roll:
WHY does everything have to be a friggin argument as soon as you get into a post :roll:
In the drawing Chris R you show the HW cylinder return as (I presume) a 22mm pipe. Currently it is 15mm, so you want me to replace the tee and all the 15mm return pipe with a new Tee and 22mm pipe, am I right?
OK, now we're getting somewhere.
15mm CH flow is a problem, but it might not be the problem.
Can you find the point where the boiler flow splits into two circuits - one through the cylinder and one around the radiators?
So far, it's looking quite likely that water is not flowing [much] through your cylinder coil. Does your water get hot, without switching on an immersion heater?
Yes, the split is about 12" from the boiler, all CH plumbing is 15mm, except the upstairs rad return which connects into a 22mm pipe (as does the 15mm HW return) before dropping back down to the ground floor where it goes into the pump n then back into the boiler
