I want to install a socket at the required height from the floor but it will be vertically inline with a light switch.
There is a only a gap between door frame & wardrobe of 100mm and i want a socket there so I can plug in a vacuum at that position.
The Light switch cable runs from ceiling to switch and all other circuit run up to loft (bungalow).
If it is ok to do, does the cable have to run behind light switch back box? Or through it?
Advise appreciated.
Garf
Advise appreciated.
Garf
