Hi all I have a problem with my combiboiler. Once therewas a problem with the water and the water presure become very low , after that for hot water I have to turn the tap in full is there any trick to gets things back to normal ? Thanks in advance
My boiler is chaffoteaux&maury
Earlier if turn on the hotwatertap half the way thorugh I will get the hot water but now I have to turn the tap fully to fire the boiler and if somebody uses the flush or open other tap the boiler stop firing.
i will get slated for this but here goes.
British Gas do a fixed fee repair as do other gas companys if i was you i would use one of these bigger companys to fix it.
