Hello to everyone.
I have a problem.
I have a boiler - probably combiboiler and when hot water is running radiators are hot. The thermostat on the boiler is turned to 0.
Can someone tell me what's wrong with it?
check your system for magnetite, as this is commonest cause of valve failure . If heavy advise powerflush or use system restorer and flush system/reinhibit after. :
I've just bought a house. It was repossessed so the heating system was drained down. I'll try to flush first. If not I'll repair or exchange the valve.
Thank you very much for advice.
