Can anybody help with toilet wastes?
Many Thanks Madrab, I've already tried pulling that piece of grey pipe out but it's wedged in their solid, don't know if they may have glued it.
What are my other options? I need to extend that pipe up ideally by about 300mm, and will then be able to reach with a new flexible pan connector?
Extension piece pan connector with smaller 90 degree pan connector
It looks like a push fit, if so then it will be tight in there, it may need cut to release it, alternatively a screwdriver teased down the point between the grey piece of soil pipe and the brown connector, only issue with that is the seal may get damaged but TBH, everything is flowing down so a little damage on the seal wouldn't be the end of the world.
As suggested if you measure the height that the pan connector will need to be at to fit the new pan spigot - from the bottom of the piece of grey pipe in the socket in the floor to the centre point of the new pan spigot, then you can leave the grey piece in, use a 110mm outlet angled pan connector and a 110mm outlet extension, that can be curt to size, if needed.
Many Thanks CBW and Madrab, really appreciate it.
Would these two items be OK as they are telescopic to save me cutting? Or do I need that 90 degree you mentioned?
And the below extension will fit inside that grey pipe piece inside the brown pipe?
And then the pan connector will insert into the extension on one side and the toilet pan on the other?
My personal preference is rigid pipework, but if you insist on using flexible, consider this
