Can anyone help Baxi Bahama
9 Dec 2005
Kent
Hello
I have just discovered this site looking for info on my Baxi I wonder if any one can advise me please.
I have a Bahama 100 which frequently locks out, sometimes once a day
I called a corgi engineer who fitted a new fan whihc it needed but he did not resolve the lock out problem He disconnected the overheat thermostat and suggested that I try it for a few days like that. It still locks out
He says that he has checked everything else and suspects that it may be a damaged board causing the lock out.
Does anyone have any experience of a boiler doing this when the board was at fault. Any experience or ideas would be appreciated
The boiler used to sit above a cooker and was probably too low .
If you do a search you'll find 38 billion posts on bahama's locking out. 2 options:
1) call potterton
2) scrap the heap
Well actually short circuited rather than disconnected.
Minimum gas settings are responsible for a lot of faults. Its a pity many CORGI people seem so reluctant to learn how to check/adjust them.
Many thanks for the responses and yes I would scrap the heap if I could afford it but, sadly not at the moment.
It`s nice to know that people do take the time to help each other out
I have to agree with pedantic :shock: :shock: :shock: :shock: .
You NEVER disconnect/bypass a safety device.
I've had a few Baxi Bananas with intermittant gas valve failure leading to lock out.
are you sure he`s a corgi engineer, only an idiot would leave the overheat stat linked out.
