Can anyone help me purchase the correct replacement plug?
Since the original also has timers and a load of sequences built in, it's not really that easy. In the main the lights are so cheap, easier to just replace the lot.
Understood...annoyingly they are mounted to a first-floor gutter though and I do not have ladders :(
You just need a new PSU.
Please post your photos. I don't use reddit
It needs to be fitted indoors or in a weatherproof enclosure
Or, when you said "plug" did you just mean the plug on the cable? Not the power supply?
For an exact replacement, if you buy a set of 100 chaser lights (any colour) from B&M they will have the exact same power supply. However, going off your reddit post, if the new 3.5V power supply you tried didn't work at all, I'd suggest the fault lies within the lights themselves. With that supply, you'd expect every other LED to light up, so half the set should work. Also from your reddit post, if you connected them to a 31V supply that would almost certainly have destroyed them since they're designed for 3.5V, you probably just need a new set of lights.
