There could be the odd drop in the well that the bleed screw sits in, but once thats gone, all should be dry.
Any tiny leak could well take up - this often happend with any mechanical joint - until the next time its disturbed. Also, the heat from the rad will also evaporate any tiny seepage, often enough.
John
