Hi all I am in the process of renovating a shop attached to my house, and installing 50 mm of insulation plus 12.5 mm plasterboard to all internal surfaces of outside walls, the main 3 phase supply cable, going to the meter, is fastened to the wall I want to insulate which means it would be buried about 40mm below the plaster. I intend to fit a 2/3mm steel shield over the top of the cable mounted on wood bearers to ensure anti penetration protection. Would this be acceptable and would I need to to earth the steel plate?
Thanks in advance for any advice
