I have an exceptionally large doorframe (2280 x 1040mm) which is hideously out of square (width difference of c 15mm between widest and narrowest points).
I'd like to order a new custom made frame/door combo but the question is whether I can fit this into the existing door frame without compromising strength and security. This is the external front door.
I'd need to place shims in the gaps to straighten everything up as if I was installing in a brick rough opening and then tidy up with some moulding of some description. If you think this is feasible, what sort of screws should I use to attach the new frame to the old frame with and what sort of spacing.
Many thanks.
Many thanks.
