can I join push fit 32mm waste to solvent weld 32mm ???
2 Mar 2004
Hopefully the answer is yes but do you have any suggestions for the actual; fitting I would need
cheers in advance guys
Yes, any 32mm compression coupler will do it. You can get them from pretty much anywhere that supplies plumbing stuff
thanks for the replies guys
I'll go and get a 32mm compression coupler then
cheers
